Här är GM's info bullentin från 2008 om vilka versioner av C5 modeller som är berörda.
GMP06-029 - 05081
Special Policy Adjustment - Electronic Column Lock System
VSU20061001
MODELS:
1997-2004 CHEVROLET CORVETTE EQUIPPED WITH A MANUAL TRANSMISSION (MM6/M12)
1997-2000 CHEVROLET CORVETTE EQUIPPED WITH AUTOMATIC TRANSMISSION - EXPORT VEHICLES ONLY
2001-2004 CHEVROLET CORVETTE EQUIPPED WITH AUTOMATIC TRANSMISSION - EUROPEAN EXPORT VEHICLES ONLY
DESCRIPTION:
SPECIAL POLICY #05081
DATED: FEBRUARY 8, 2006
IMPORTANT:
BEFORE PERFORMING THIS REPAIR, VERIFY THAT RECALL 04006 HAS BEEN PERFORMED ON THE VEHICLE (LABOR CODES V1144, V1145, V1153). IF THE REPAIRWAS NOT PERFORMED, THEN PERFORM THE REPAIR IN RECALL BULLETIN 04006C, AND SUBMIT THE CLAIM USING THE APPROPRIATE RECALL LABOR CODE.
DESCRIPTION:
Some customers of 1997-2004 Chevrolet Corvettes equipped with a manual transmission (MM6/M12); 1997-2000 Chevrolet Export Corvettes equipped with an automatic transmission; and 2001-2004 Chevrolet European Export Corvettes equipped with an automatic transmission may have a condition where the column lock may fail to unlock the steering column when the vehicle is started.
SPECIAL POLICY ADJUSTMENT:
This Special Policy covers the condition described aboveuntil February 29, 2008, regardless of ownership. The repairs will be made at no charge to the customer.
For vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after February 8, 2006, are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to February 8, 2006, must be submitted to the Service Contract provider.
CORRECTION:
Refer to Special Policy Bulletin #05081 for further information.
EFFECTIVE DATE:
Owner mailing is scheduled to begin February 15, 2006.
GENERAL INFORMATION:
For U.S.: Parts required to complete this Special Policy procedure are to be obtained from General Motors Service Parts Operations (GMSPO).
The Parts list follows:
Part Number: 89023816
Description: Harness Kit, Strg Whl Theft Dtrnt Lk Shorting (US Vehicles Only)
Quantity/Vehicle: 1
Källa:
http://www.c5registry.com/technical/GMP0g.htm
