Min efterlängtade beställning..
.... har inte anlänt ännu, men om nån är intresserad så ser den ut som följer.
Jag vet iaf vad jag kommer göra när grejerna kommer.. skruuuuva
Corvette Glove Box Liner, 1963-1967 A3319 1
Corvette Glove Box Liner Screws, 1963-1967 A1613 1
Corvette Shifter Console Plate, Rear, With Power Windows, 1963 35304 1
Corvette Shifter Boot, 4-Speed Transmission, 1963 A2141 1
Corvette Ashtray, 1963-1976 A2325B 1
Corvette Ignition Key Blank, Octagon, 1953-1966 A1600 3
Corvette Jacking Instruction Decal, For Cars With Standard Wheels, 1963-1966 A6395 1
Corvette Jacking Instructions Decal, For Cars With Knock-Off Wheels, 1963-1966 A6326 1
Corvette Jack Compartment Board Bezel, 1963-1967 A3284 1
Corvette Jack Compartment Board, Convertible, 1963-1967 A3282 1
Corvette Shifter Console Trim Plate Screws, 1963 45352 1
Corvette Shifter Boot Screws, Lower, 1963-1967 A5513 1
Corvette Antenna Cable, With Serrated Nut, 1956-1966 39829 1
Corvette Hood Bumper, Rubber, 1953-1976 26917 2
Corvette Horn Button Contact, Without Telescopic Column, 1963-1966 A8650 1
Corvette Horn Button, 1963-1964 A1395 1
Corvette Horn Contact Brush, 1963-1968 35375 1
Corvette Seat Foam Set, 1963 A1703 1
Corvette Wiring Harness Cover Plate Clip Kit, 1963-1967 53894 2
Corvette Floor Wiring Harness Cover Plates, 1963-1964 37557 1
Corvette Bumper, Rear, Left, 1963-1967 A8141L 1
Corvette Floor Pan Plastic Plug, 1-1/4" 26941 4
Corvette Antenna Nut, Chrome, 1963-1964 A1228 1
Corvette Antenna Bezel, 1963-1968 A9917 1
Corvette Antenna Bezel Gasket, 1963-1982 A2192B 1
Corvette Sway Bar Bushings, Front Or Rear, 3/4", Polyurethane, 1963-1967 A7264 1
Corvette Trailing Arm Pivot Bolt Kit, With "TR" Headmark, 1963-1982 29091 2
Corvette Shock Absorber Upper Bolt Kit, Rear, 1963-1982 27022 2
Corvette "Reactek" Shock Absorber, Gas, Front, ACDelco, 1963-1982 A3652 2
Corvette Body Weatherstrip Kit, Convertible, 1963 45805 1
Corvette Trailing Arm Alignment Shim Set Stainless Steel, 1963-1982 43548 1
Corvette Control Arm Shaft Washer, Upper, Front, 1963-1982 46125 2
Corvette Car Cover, Gray, Spunbond, Aqua-Shed, 1963-1967 52871 1
Corvette Windshield Washer Nozzles, 1963-1967 A1452 1
Corvette Washer Nozzle Gaskets, 1963-1967 A8857 1
Corvette Windshield Wiper Blade, 1963-1967 A8024 2
Corvette Interior Screw Set, Convertible, 1963 A5481 1
Corvette Challenger Speakers, Custom Autosound, 1963-1982 43687 1
Insulating Exhaust Wrap 88-0173-1 2
Corvette Clock Retainer Clip, 1963-1967 25284 1
Corvette Light Bulb, Interior, # 1816, 1963-1974 25448 5
Dash Paint, Semi Flat Black 88-0290-1 1
Corvette Engine Compartment Seal Kit, For Cars Without Air Conditioning, 1963 25778 1
Corvette Exhaust Bezels, Stainless, 1963 A2094 1
Corvette Windshield Wiper Motor, Restored, 1963-1967 43041 1
Core,Wiper Motor,63-67 DEPN43041 1
Corvette Firewall Grommet, 2 Hole, 1963-1967 39122 1
Corvette Firewall Grommet, 4 Hole, 1963-1967 37863 1
Corvette Seat Covers, Vinyl, 1963
Please Select
1963 Black 28044;A1957B 1
Corvette Carpet Set, With Foam Backing, Convertible, 1963
Please Select
1963 Black 28069;A1995B 1
Corvette Sunvisors, Coupe, 1963 Or Convertible, 1963-1964
Please Select
1963 All & 1963 Convertible, Black 28032;A1802B 1
Corvette Armrest Pads, 1962-1964
Please Select
62-64 Black 28000;A2317B 1
Corvette AM/FM/iPod Stereo Radio, Manual Tuning, Ken Harrison, 1963-1967 55461 1
Please Select
Please Select
Please Select
Please Select
1963 C2 med eller utan tak...
Re: Min efterlängtade beställning..
Jamen det där var väl inte så dyrt va
Ser ut som en gedigen lista! Några till såna och bilen är som ny...
Lycka till med montaget av alla fina delar, ser fram emot utförlig rapportering med många bilder!
Mvh: Daniel
Mvh: Daniel
Corvette 427-69
Camaro Z28 -71
Smuggler 24 -85
Harley 750 -46
Camaro Z28 -71
Smuggler 24 -85
Harley 750 -46
Tyvärr säljs ju inte delarna på IKEA, så helt gratis blev det inte.
Förbannat roligt ska det bli iaf
Vilken fest det blir då !!!!!!!!!!!!!
Det blir askul !LÖVIS skrev:Vilken fest det blir då !!!!!!!!!!!!!
Det första jag ska göra är att åka med klädsel och stoppning till tapetseraren, sen bär det av med däcken till gummijuckaren och sen tar jag semester i 2 veckor
Va kul du får ! Snart är det dax att gå hem. Sitter kvar på jobbet/ kontoret fortfarande.
På väg hemåt med hela bilen fullproppad med delar
Eureka !
Nu har jag gått genom allt och varenda pinal var med
skönt..
Va härligt, nu ska det meckas förstår jag. Go for it !!!!
Jäklar va nice, massa roliga timmar i garaget
_________________________
Målarn....
Målarbilen
Målarn....
Målarbilen
