Nya Corvette delar till salu
Antal Art Nr Benämning Modell Årsmodell Pris
3st 42936 Rear licens bezel C3 68-73 1299
1st 40608 Coilspring front 520lbs C2-C3 63-82 1120
1st CDO4213 Window lift motor C3+GM 68-75 2350
1pair 7221 Seat foam C3 70-74 3075
1st 4061-20 Header rmolding Black C3 69-75 1120
1st X2001 Exh Extension SS C3 68-69 630
2st 34117 Wipermotor C3 74-82 1795
1st X2019 Exh bezels ss C3 70-73 1120
1st 4249-53 Armrest Dark sadle leder C3 72- leader 1150
2st X2198 W strip kit cab C3 69-72 2500
1st 4289-30 Inner door handles red C3 69-72 300
1st 44920 Inner door handles black C3 68-79 200
1st 399082 Heater core no AC C3 68-79 1800
1st 2019 Front licens braket C3 68-72 355
1st 42107 Front licens braket C2 63-65 350
1set 4417-30 Door panel Red LH C3 69 Deluxe 5180
1set 4418-30 Door panel Red RH C3 69 Deluxe 5180
1st 4906 Luggage Rack Crome 6h C3 68-75 2950
2st CLR-6 103055 Luggage Rack SS C3 68-75 2950
1set 475630 Matta röd C3 68-72 1259
1set 3 pkt,bältes sats Röd C2-C3 63-74 2790
1set 493115 Bakljus LED C3 68-73 2800 sålda
1set Matta front sadle 820 C3 70-76 1899
1sats Powesteering kit BB C2-C3 65-74 10000
1par Door panel Black Std, C3 69-76 6995 sålda
1st 43315 Gastank C3 68-69 2525
1st 43317 Gastank C3 69-70 2525
3set 1443 Tankband C3 68-74 350
3st X2260 Tank neck boot C3 68-74 350
5st X2628 Tank sender C3 68-74 980
1st Kylare C2 63-67 8500
1st 6139063M Kylare LS konvertering C2 63-67 10000
Med elfläkt
1st 142088 Motorhuv presmolded NY C2 327 63-67 10000
1set Mattor med logga C6 15-05-13 1299
1st 48421 Matta ebony GM C6 05-13 895
1st 50426 Mild to wild remote C6 06-13 1595
1st Wonderbra (Behå) C6 05-13 1499
1st 21121SLP SLP Blackwing luftfilter C6+Z06 08-11,06-11 3500
Car Cover till alla Corvette modeller Från 595 – 1695:-
För Invändig och utomhus förvaring
Ny Corvette delar i lager
www.classiccarservice.se
Service,Delar och Tillbehör samt renovering av Corvette
Tel o Fax 046-705969 info@classiccarservice.se
