P0480 FC Relay 1 Control Circuit
en kod !!! P0480
en kod !!! P0480
vad betyder på svenska denna kod ?
c5 z06 2002
A&A kompressor
pfadt co
B&M ss
cartec xtreme koppling
alu sh
Lg longtubes
tyvärr såld nu
Blev nyss med c6 z06
PFADT
Akrapovic
OZ
Cammotion
A&A kompressor
pfadt co
B&M ss
alu sh
Lg longtubes
tyvärr såld nu
PFADT
Akrapovic
OZ
Cammotion
gjorde en snabb googling och hittade följande:
The P0480 means there is a wiring problem (either a short or an open circuit) for your LOW speed engine cooling fans.
You should get this resolved soon, as that DTC disables the LOW speed fan circuit. You should still have HIGH speed fans ..... but I'd not risk this ... you could overheat the engine if the HIGH speed fan circuit also goes out.
hoppas du blir lite klokare
